brackets for 1 wire delco alternator and KRP ps pump on ls3?
Old 10-10-2011, 12:09 PM
ramey's Avatar
Default brackets for 1 wire delco alternator and KRP ps pump on ls3?
I've been skimming around the net to mount these up, alternator is a GM 1 wire mounted low (or mid) on the passenger side and the PS pump is a KRP circle track unit, low to mid mounted on the drivers side;
they were on a windsor.
any ideas how best to mount these up to a fuel injected LS3 with drive by wire (which blocks the upper mounted systems)?
any help is appreciated.
Quick Reply: brackets for 1 wire delco alternator and KRP ps pump on ls3?
