12 Second Club - dissipointed 12's
View Full Version : dissipointed 12's
1998MysticZ28
10-11-2011, 01:06 PM
Car did 12.1 @112, Spun out of the hole and bounced of the limiter on 1-2 shift. it was hot as hell though.
LS6 ported heads
232/236 114 lsa cam
ls6 intake
3600 9.5 billet converter with performabuilt stg 2 4l60e
10 bolt 4.10 gears.
Will upload video later
BOBS99SS
10-11-2011, 01:12 PM
if you spun alot,and there was really bad air out ,thats not to bad, suspension mods?tires?what did you launch at? post your time slip up as well
1998MysticZ28
10-11-2011, 01:20 PM
BMR subframe connectors, lower control arms torque arm panhard bar lca relo, front sway bar, all adjustable.
Tires are nitto NTO5r 275/40r17 Launched at like 2300. Will do if I can find it, going to get fm4!
1998MysticZ28
10-11-2011, 03:23 PM
http://www.youtube.com/watch?v=exkVEzrwJyA
blk/slvr02ss
10-11-2011, 05:16 PM
Seems to b running better or should i say shifting better !!!!!what was your 60 ft ? That was a good time for the heat and it will b in the 11's when it cools down !U Need to come out @ 1000 rpms and flash the converter !
1998MysticZ28
10-11-2011, 06:25 PM
Joe you have to come out next time with us
blk/slvr02ss
10-11-2011, 06:29 PM
Yea let me no and i will come out and take my bike i just bought and run it and maybe hit 9's if i learn how to launch it !!!!
1998MysticZ28
10-11-2011, 07:57 PM
haha nice, maybe next week
JetBlack98Z
10-19-2011, 12:20 PM
Sounds like that thing needs to shift alittle higher into second gear, other than that looked like a good clean pass.
speedtigger
10-19-2011, 12:40 PM
In the video it sounds like you shifted out of first at about 4500 RPM. I assume this was a different pass then the one you are referring to above. The 2-3 shift sounded low too. With that cam I am guessing it would like 6500-6700 shift points?
