power steering lines
I am getting ready to have some power steering lines made. I currently have an AN fitting in the pump connecting to some braided line. I am taking that off. I do not have the pump in front of me, and I wanted know what the size of the fitting that goes directly into the pump? The 1 I have the AN fitting going into. It is a p/s pump from a 2006 Escalade. I am guesing al ot of the trucks of that year are the same.
Thanks
Thanks
Has anyone used this fitting for the high pressure side?
http://www.jegs.com/i/JEGS+Performan...00706/10002/-1
JEGS Performance Products #555-100706
Power Steering Adapter Fitting
-06AN x 18mm x 1.5 O-Ring
What is up with -06AN? Is that the same as -6AN?
ya, sorry about that -- I was thinking gear, not pump. the pump is M16x1.5 (go about 3/4 of the way down this page). And -06 AN is the same as -6 AN -- that's just a typo on Jegs' part. Go with one of those and one M18x1.5/-6AN and you'll be golden.
return side: 'power steering repair kit' from edelmann's, PN 39106 (your idea)
High-pressure side: -6AN x 18mm x 1.5 O-Ring at the gear box & 16mm x 1.5 at the pump.
I have everything on except my new -6AN x 18mm x 1.5 O-ring
Thanks,
Brandon
