valve spring life
valve spring life
Just curious as to how often you should change valve springs on a heads/cam car. I'm going to run ported LS3 heads and have pat G spec me a cam, cam will be on EPS lobes.
How often do you change springs and please post your cam specs! I really don't want to run more than .625 lift unless someone talks me out of it...
I ran a 0.650 PRC double spring with a 0.561 cam for nearly 3 years and almost 100k. I had a cam hardness material failure which gave me opportunity for a new build at that point. I checked my springs though around once a year so it'd be good to monitor them. The closer you are to the lift limit though, the more I'd check on them.
I've got an LS7 with a .656" lift cam. My Patriot extremes have been on for 23,000 miles with many a 7,200 rpm blast. Patriot recommends replacing them at 15 - 20k. I'm doing them this week.
well it would be on pat G's EPS lobes which are supposed to be MUCH easier on your valvetrain. I'll obviously discuss this a little more with Pat when I send in the cam sheet but opinions and experience are worth their weight in gold.
litle we are gonna have to meet up here in a few months and go for a cruise. or better yet you can come and let me have some parts off your car how far is burbank from indy?
I have had an MS4 since October of 09' (0.649"/0.609") with PRC Golds (0.650"). I swapped them in March of 11' with around 20K on them. I am now using PRC EHT (0.675") but I have yet to get the Gold's tested. I will someday soon, haha.
If you want a loooong life spring get the PAC 1521 duals. I've had them in my car with three sets of heads and about 20k miles running cams up to .660 lift and 2.200 inch valves. When Richard at WCCH (proheads.com) did the Stage 3 porting he checked the springs and they were within a couple pounds of new pressure. That was after about 16k miles with a lot of dyno and street time on them.
I'm still running them and will check them again at around 30k but I expect them to still be in excellent shape.
