Gen 5 Camaro Tuning, Diagnostics, Dyno results - Wiring Harness on my LS3
View Full Version : Wiring Harness on my LS3
Rustoleum
10-12-2011, 12:01 AM
Hi All,
I bought a motor only from a camaro SS '11 stock LS3 6.2L with 5K miles on it in a wrecking yard. Unfortunately, the engine ecm and wiring harness were gone. I'm trying to find a company that has the right engine wiring harness and can set me up with the correct ECM. It won't be going back into a camaro but into a '55 chevy I'm building. I bought a new magnum T'56 manual 6-speed that I will be hooking up to it. I plan on just keeping it stock for now, in that it already has 426hp. Maybe later, I'll add a mild or hot cam. Right now, I'm just trying to find out what is the best harness and the ecm to get and whether it can be programmed to run this LS3. :drive:
OrangeChevyII
10-12-2011, 09:19 PM
PSI makes one for you.
donnie_19
12-26-2012, 08:17 PM
Newby here who is PSI. I am in the same boat transplanting in a 78 vette
