C6 manifolds in a 68-72 GM A-Body?
Anyone try using C6 manifolds with their swap? I came across some for a good price and plan on giving them a shot (and flipping them later for a turbo setup).
Most of the C5/C6 Exhaust Manifolds well not work with a A-Body.. the Exit points on the Manifold are almost centered and will run into the Crossmember. But if anyone has, they well ping in.
If you use them flipped for a Turbo. shouldn't be any problem, go for it then.
