Chevrolet Camaro 1967-2002 - It lives!
scatillac
10-12-2011, 07:22 PM
After almost a year, it's finally off the jack stands and is driveable.
Still a lot of finish work and tuning to do before I start on the body and interior.
OutlawDrifter
10-13-2011, 09:39 AM
very cool! the 67/68's have always been my favorite of the first gens, much cleaner lines. it should scoot right along with that LS7!
efs69
10-13-2011, 04:30 PM
Nice job. Looks really ggod. I am starting on my 69. What engine padapters, headers and pan did you go with?
scatillac
10-13-2011, 07:12 PM
Nice job. Looks really good. I am starting on my 69. What engine adapters, headers and pan did you go with?
The motor mount adapter plates are from Speedway (#91618016) with Energy Suspension mounts. The headers are modified Dynatech 1 7/8" and the pan is a Moroso #20140 (requires remote filter).
efs69
10-18-2011, 07:34 PM
Thanks for the info. I was looking at the Dynatech headers. what did you modify?
scatillac
10-19-2011, 01:56 AM
#1 primary. It contacted the adapter plate and mount. It also ran too close to the steering shaft (rack & pinion steering).
Another consideration is oxygen sensor clearance if you use a 4L80E transmission. There's less than 1/8" between the tip of the sensor and the 4L80E pan, which means that you have to remove the headers to install/replace the sensors.
Dynatechs have one of the better, if not the best collector sealing systems in the business.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
