Torquer V3 my first cam.
Old 10-12-2011, 08:33 PM
cknoma2005's Avatar
Default Torquer V3 my first cam.
I finally got the cam installed after having the parts for four months now. Can't even begin to express the feeling of having the beast come to life after what can only be described as a personality transplant. I wasn't expecting the car to idle as good as it did before the tune, but it did. The only thing better than having a cam is having a cutout to accompany it. It sounds so mean at idle and wot. What is next? I'm thinking an ls7 clutch in the not to distant future. The oem clutch just can't hang. Here is the dyno sheet.
416hp\389tq with 155,000 miles on the motor. Alllrighhhttt!!
Old 10-12-2011, 08:37 PM
msydow's Avatar
LIES...ALL OF THIS IS LIES.
j/k cody, glad you're having fun. really didnt expect that
clutch to last this long.
Old 10-12-2011, 08:39 PM
cknoma2005's Avatar
Kudos to msydow for doing the install. Thanks again man.
Old 10-12-2011, 08:43 PM
msydow's Avatar
no prob bob...still got those heads here waitin for you
Old 10-13-2011, 11:15 AM
TrentSS's Avatar
That's a nice fat torque curve you've got there! Great under-the-curve-power...
Old 10-17-2011, 11:55 AM
RedZed's Avatar
Congrats dude, you just sold me on upgrading to the same CAM for my 2001 SS A4 w/140K miles. Gotta love that solid torque curve
Did you also upgrade to RR's, ported oil pump and double timing chain w/this setup?
Old 10-17-2011, 01:50 PM
T AM's Avatar
Nice results! I'm running the same cam and I've been very happy with it.
Old 10-17-2011, 02:03 PM
cknoma2005's Avatar
No roller rockers. I bought a set of used ls1 rockers for like $30 on here and swapped out the shitty bearings with the comp cam trunion upgrade kit. Worked great and it got rid of that sewing machine noise from under the hood. I also installed a Melling ls6 oil pump, ls7 lifters and trays, 25% slp underdrive pulley, 160 degree thermostat as well as new push rods, springs, retainers, locks, seats, stem seals, arp head bolts and gaskets . Pretty much everything thats needed for a proper cam swap. Call Texas Speed and Performance. Tell them what kind of power you want to make and they will hook you up.
Old 10-18-2011, 02:42 PM
93LS1Ws6's Avatar
Awesome numbers. I Just got done with my built 347 and was gonna keep it stock cam that way i could break in my torque converter. But went t56 now and have a good ls7 clutch for it so i think im gonna go with this cam. Seem to be a good cam on the dialy but makes good numbers. Thanks man!
Old 10-18-2011, 04:00 PM
30th t/a's Avatar
Nice numbers - when I made 416rwhp I ran a 11.9@120...on the 10 bolt w/ 4:10s.
Old 10-18-2011, 04:13 PM
schufflerbot's Avatar
dang!! great #s.
my torquer V2 was great for the first 6 months... then it started to feel slow!
*shrug*
guess i need to upgrade to the V3
Old 10-18-2011, 05:14 PM
cknoma2005's Avatar
Are those the #s you made with the V2 in your sig?
Old 10-18-2011, 05:17 PM
bigchief52780's Avatar
did you have to flycut your pistons for that cam to work?
Old 10-18-2011, 05:19 PM
cknoma2005's Avatar
nope...
Old 10-18-2011, 09:40 PM
RedRallyeZ's Avatar
Awesome numbers man.
I have that cam with a set of PRC 5.3L heads and when i had my tune and install done, I put down 384RWHP, but that was with my unlocked stall a4, which we later found out was completely shot.
Now that Im an m6, seeing those numbers makes me want to re-dyno even more than i already do, haha.
Old 10-18-2011, 09:46 PM
msydow's Avatar
redrallyez, whats the chamber size on your 5.3's? i have a set im trying to get the OP to put on his car, just not sure if they've been milled too much or not. gonna check PTV anyway just dont wanna waste time checking if they wont fit.
sorry cody, i'll get those heads on your car one way or another...
Old 10-19-2011, 01:37 PM
cknoma2005's Avatar
Op???
Old 10-19-2011, 03:01 PM
reeperz28's Avatar
High mileage ftw. 130,000 here
Old 10-19-2011, 03:24 PM
Austinma62's Avatar
Nice gains from a cam swap! How does it sound at idle?
Old 10-20-2011, 09:03 AM
Rare96LT1Formula's Avatar
Some nice numbers for your mods. Congrats. Do some research before you invest in the LS7 clutch. Alot of guys complaining about that setup especially when dumping the clutch, beating on it, etc. Check out Monsters stage 2 package imo.
Quick Reply: Torquer V3 my first cam.
