Jeff@LPE
10-13-2011, 09:03 AM
http://www.lingenfelter.com/images/jpicture/img_5343-2.jpg
The new Specter Werkes GTZ heat extractor hoods are in stock and ready to ship. $895.00
The new Specter Werkes Camaro SS GTZ Hood is a fully functional heat extractor hood that adds an aggressive look and helps performance by removing the hot high pressure air from your engine bay.
The Specter Werkes GTZ heat extractor hood is manufactured by Advance Composite Specialties using ACS's validated RTM process. RTM or Resin Transfer Molding technology creates a part of OEM quality. Fiberglass is injected into a mold and then compressed under high pressure. This manufacturing method creates a panel that is smooth on both sides with a consistent thickness across the entire surface. The controlled fiberglass/resin composition of RTM, reduces cure times and eliminates the possibility of "wet" parts being removed from the mold prematurely. All of which is impossible with the standard hand laying process. Panels are then trimmed using a CNC robotic water jet for a clean, smooth cut on every part. The result is better fitting panel, reducing body shop installation and fitment times.
The GTZ heat extractor hood is a high quality direct bolt on that includes all necessary hardware including grill screen and bezel. GTZ hood is also compatible with the Eforce supercharger package, and the Magnuson TVS1900 package.
Click here to got to store and place order now (http://www.lingenfelter.com/mm5/merchant.mvc?Screen=PROD&Store_Code=LPE&Product_Code=SWS10501001&Category_Code=)
http://www.lingenfelter.com/images/jpicture/img_5267-1.jpg
