Convertible Vehicles - Stiffening Up a Convertible Suspension
cyberleader
10-14-2011, 07:23 PM
on an 02 camaro convertible... what should be the preferred order one replaces stock suspension parts with performance parts as the funds become available?
shine
10-14-2011, 07:52 PM
-Good shocks, like Bilstiens or Konis + lowering springs.
-Subframe connectors - UMI just released 3 point SFCs. Mine are waiting to be installed...
-Hollow sway bars
HASTINGSRJ
10-15-2011, 06:07 AM
agreed with above, but add a cage
GR8RYD
10-15-2011, 07:59 AM
-Hollow sway bars Just my preference, but after the shocks I would install a 3 point strut tower brace. Makes a huge difference in the front end.
UMI Performance
10-16-2011, 08:01 PM
How many miles do you have on your vehicle now? Any suspension mods now? What type of power adders?
Let us know and we are glad to help. Thanks!
Ryan
38DD2436
11-03-2011, 06:15 PM
Why do you suggest hollow bars?
96SilverZ
11-03-2011, 07:07 PM
I've heard the three points can cause the windshield to crack?
Saturn5
11-03-2011, 07:55 PM
They're lighter. The center of a bar adds very little to the stiffness of the bar, so a hollow bar will have nearly the same stiffness as a solid one, but be lighter.
BobDoLe
11-03-2011, 10:05 PM
you should probably go with subframe connectors sooner than later.
99'CajunFirehawk157
11-03-2011, 11:26 PM
-Hollow sway bars
I did exactly what he said:
shocks first (bilstein)
then 2 pt bolt in sfc's (have 3pt UMI's on stand bye in garage now)
hoctchkis strut tower bar
(have not done lowering springs)
https://lh6.googleusercontent.com/-RK6OdLBv524/TYZ894hc3GI/AAAAAAAAB8k/lZqe4jxUThI/s450/IMG_0876-2.jpg
RONIN LSX
11-04-2011, 01:30 AM
Since I am looking at 700+ at the crank, I was thinking of running some angle iron or box channeling along the inside of the floor along the rocker panels, as well as a tunnel brace.
