Ls1 S10
Ls1 S10
Year: 1998
Make: Chevrolet
Model: S-10
Price: $8000
Mileage: 0
Private or Dealer Listing: Private Listing
Location (State): KS
Color: Blue
Transmission: Manual
LS Engine?: Car has LS engine
5.3 block bored to 346 ci
stock ls1 pistons, rods, and crank
arp rod bolts
stock 5.3 heads ported and polished also milled to increase compression
compression ratio 10.8:1
rollmaster double roller timing chain
02 Z06 cam and valvespring
Manley hardened pushrods
GMPP single performance carbureted intake manifold
Holley 670 street avenger carb with vacuum secondaries and electric choke
MSD 6010 programmable ignition box with 2 step and nitrous retard capability
Sanderson 1 5/8 shorty headers with SCE copper gaskets
LS2 corvette oil pan, windage tray, pickup, and dipstick
Trans:
6-speed
Diamond stage 2 clutch
3-4 syncros going bad, will replace or buy the syncros before selling
Will stay in all gears but there is grinding with fast, hard shifts into 3rd and 4th
The VSS in the transmission might also need to be replaced, so the speedometer doesn't currently work, an easy fix but with school haven't had time.
It needs a shifter boot, right now there is just a hole there
Suspension:
Cal Trac traction bars
QA1 fully adjustable coil-ver front suspension
lowered rear leaf springs with Nitro drop Shocks
Larger diameter sway bars
rear mounted battery
Interior:
upgraded Sony speakers all around
JVC head unit
Fully custom AutoMeter gauge display
Brand new carpet recently put in
Rear End:
8.5 inch swapped in w/ drum brakes 3.73 gears and a PowerTrax Locker with brand new springs
Braided brake lines
Upgraded drilled and slotted disk brakes with caprice calipers
Need truck gone for financial reasons. Truck is Located in Manhattan, KS. Fuel gauge doesn't work it but it is an easy fix just haven't had the time. Does not have A/C either, have everything but the compressor, never installed it mainly cause i didn't care to put have it. . If not local pickup the shipping will need to be paid for and set up by the buy. I have a flexible schedule i can deliver truck to delivery truck when ever. Asking 8,000 truck is worth it with motor and transmission not to mention the suspension. Will listen to offers but don't try to low ball me. PM with any other questions. Will also look at trade offers.
pics: http://s816.photobucket.com/albums/zz83/pudge600/
