JimMueller
03-09-2004, 04:20 PM
I have the opportunity to pickup a shortblock which has Wiseco nitrous pistons in it. I was told that they are domed but have valve reliefs. The heads which would be going on the block are 5.7L heads milled .030. Should I be concerned about compatibility?
I guess what I'm saying is, the amount of milling on the heads won't cause problems with the dome on the piston? I was told he had 11.5:1 compression with his last set of heads.
Thanks!
Thanks!
