low drag suspension
low drag suspension
ok i have lca's,lca relocations,panhard rod,strut tower brace,and bmr lowering spring,stock shocks and struts,wanting to change the shocks and struts and go with something like qa1's , but the car is really low i was told that it wont hook with the springs i have but i love the look ,should i switch springs ,im doing stock bottum end with heads cam turbo,th400 with 3600 yank just want to make sure it hooks
LS1Tech Premium Sponsor
We have customers going 9s on our lowering springs out back with their front Strange shocks set up to an even lower ride height than the rear. Is it ideal? No. Will it hook? Yes, you can still get a lowered car to hook.
I suggest 300lb front drag springs if you're looking to maximize your drag setup with our rear springs.
