stock ls3 VS 102 FAST intakes
Old 10-17-2011, 12:50 AM
Blackbird-WS6's Avatar
Default stock ls3 VS 102 FAST intakes
has anyone compared a stock ls3 intake VS a 102 FAST on a 408??
is the FAST102/TB worth the extra $1000 over a stock ls3??
Old 10-17-2011, 11:10 AM
Anyone??
Old 10-17-2011, 12:22 PM
Louis's Avatar
Its tough to say, typically, no. Lately, We have been seeing some decent gains, but nothing like the LS7 FAST or the LS1/2/6 FAST.
Old 10-17-2011, 12:29 PM
yea thats the problem, cant really fine no "real" info on the two being compared on a engine that most people use
most likely ill be going with new PRC 250cc ls3 heads from TSP and a ls3 intake on a 408ci
now if im only going to gain 10hp and spend $1000 i dont see it worth it
Old 10-17-2011, 02:41 PM
WKMCD's Avatar
35RWHP over a well ported LS3 intake on the 427. That was after some serious modifications to the FAST 102 including a 107mm NW TB.
Old 10-17-2011, 02:52 PM
408 VS 427 so im sure that 427 would like it more
my goal is 525rwhp
Old 10-17-2011, 02:56 PM
Louis's Avatar
Id say those are abnormal gains Kevin, but more on track with the LS7/Gen3 FAST, which is where it should be.
typically, we can 10/10 with just an out of the box FAST. To most of my customers, we dont sell it unless they are looking for max effort.
Do you know what the 107 is/was worth? I didnt think Nick was making them?
Old 10-18-2011, 01:57 PM
SweetS10V8's Avatar
Little to none. Ive seen testing on 750fwhp LS engines that changed from a FAST 102mm intake with a 92mm TB to a 102mm TB, on a FAST 102mm intake. The gain was 2hp and it was only at the very last few 100 RPMs
99.9% of people do not need a 102mm throttle body,everyone should be running a 90/92mm. Its the runners that make the power, not the size of the opening for the throttle body.
Old 10-18-2011, 02:01 PM
t5munoz's Avatar
I would say get ahold of Tony Mamo and see if he can lead the way for you hes the one who does alot of porting on Fast 102!!!
Old 10-18-2011, 02:15 PM
i think my best bet is to stick with a ls3 intake
Old 10-18-2011, 10:20 PM
mike c.'s Avatar
I did on my 402ci. I had l92 ported heads and a l92 intake. Went to a fast 102 and gained nothing on the dyno. I then went to trickflow heads with a fast and gained nice over the ls3 stuff. then had mammo port the fast 102mm and gained again. You could get the ls3 intake port matched and make a small gain..
Old 10-18-2011, 10:22 PM
what L92 heads did you have?
Old 10-19-2011, 07:40 AM
WKMCD's Avatar
Hey Louis,
Hope you're doing well.
I've been told Nick isn't doing the 107mm anymore. I was lucky to get this one.
Here are the numbers:
Here's the dyno chronology:
427 Old Cam............................................605/588
427 New Cam...........................................621/601
427 Port Matched FAST w/ 90mm TB............633/616
427 Shawn Miller massaged FAST/107mm TB..656/614
It looks like Shawn managed to get the FAST to produce 35hp with the FAST. Not too bad,
Old 10-21-2011, 01:10 PM
1lejohn's Avatar
my goal is 525rwhp
I think you can reach your goal with the LS3 intake. They just peak early in the power band, but hold on to it. Our car pulls strong from 6000-7000
Old 10-21-2011, 01:15 PM
1lejohn's Avatar
Hey Louis,
How much more cash did it cost over the stock 102? I guess was it cost effective. I know that your build was a no holds bar build for a street car.
Old 10-21-2011, 01:20 PM
yea im with the ls3, no proof showing gains with $1000 more spent, plus i always can sell the ls3 and get the FAST if worse comes to it
Old 10-27-2011, 11:24 AM
1lejohn's Avatar
Yea it should work. I can't get an answer about the cost of Kevin's 102 from any one. I'm thinking $$$ or it was free due to shop bragging rights.
Old 10-28-2011, 05:34 PM
WKMCD's Avatar
I think Shawn and I both invested in making the FAST work on my build. My $$$ and Shawn's time. I don't think he's really interested in doing any more unless it's part of a complete build.
That being said, I made 530RW on my very mild build 403 with a ported L92 car intake and 90mm TB.
Old 10-28-2011, 07:00 PM
Petraszewsky's Avatar
http://forums.corvetteforum.com/c6-t...s3-intake.html
Old 10-30-2011, 09:59 PM
1lejohn's Avatar
Kevin thanks for the answer. I was thinking that he put alot of work into it and didn't want to do any more. It also makes sense that he would like to have the block and heads to mock up to check fitment, port sizes etc.
Quick Reply: stock ls3 VS 102 FAST intakes
