General Maintenance & Repairs - Rack in Pinion
T.A.Chick.
10-17-2011, 04:48 PM
Well guys it has been a while! Anyways I'm replacing the Rack in pinion in my car. I'm looking into buying one. Quality not quantity here. My first instinct was to go to my local GM and buy one there but i'm not sure if i could buy one to make a difference so I can improve the performance in my car.
Thank YOU!
ULTIMATEORANGESS
10-17-2011, 04:55 PM
do you mean rack and pinion or ring and pinion.
sorry for misunderstanding.
T.A.Chick.
10-17-2011, 05:11 PM
No lol. My bad. its rack and pinion.:newbie:
38DD2436
10-17-2011, 06:50 PM
Buy a quality rebuilt. I did mine and got a 3 year, 36K warrantee on the rack. Cardone is the rebuilder.
sjsingle1
10-17-2011, 09:46 PM
GM does not offer new racks.......you can get a GM reman tho
DropTopBird
10-18-2011, 12:02 AM
I got a remanufactured one from a place on ebay called Detroit Axle. Its been holding up great and has a lifetime warranty. Once you send back your core it was like $135. Definitely worth checking out:
http://www.ebay.com/itm/1998-02-CAMARO-POWER-STEERING-RACK-AND-PINION-ASSEMBLY-/150622190849?pt=Motors_Car_Truck_Parts_Accessories&fits=Submodel%3ATrans+Am&vxp=mtr&hash=item2311c83d01#ht_3111wt_1112
Jr.Samples
10-24-2011, 03:04 PM
Seen Cordone on ebay for 130.00 plus a 15.00 core. Yup free shipping too. Can't beat it.
Good luck.
vincew1
10-24-2011, 04:04 PM
I picked one up at Advance Auto. It is Cordone and I want to say it has a lifetime warranty. One problem: fluid lines on the front of the new Rack and pinion were bent, kinked and had been painted. A little disappointing considering I would expect better.
So I swapped out the lines on my old original unit, cleaned them out with brake cleaner and put them on the new unit. Returned my core with the bent lines and everything worked out great.
I did all this while I was rebuilding my front suspension and bushings. If this is your first time replacing the R&P good luck with getting the bolts out. One of them had to be cut with a recipro saw as it is upside down. The alternative was jacking up the engine. And you will need an alignment after the install...
Good luck!
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
