Anyone have the pinouts for L92/LY6 OBDII port?
Here is how I wired mine:
Pins 1,2,&3: Not Used
Pin 4: (BLACK) Ground, Circuit 1050
Pin 5: (BLACK/WHITE) Ground, Circuit 1851
Pin 6: (TAN/BLACK) GM High Speed LAN Serial Data Bus +, Circuit 2500
Pins 7 thru 13: Not Used
Pin 14: (TAN) GM High Speed LAN Serial Data Bus -, Circuit 2501
Pin 15: Not Used
Pin 16: (RED/WHITE) Battery Positive Voltage, Circuit 640
I hope this helps
Pin 15: Not Used
I hope this helps
The following users liked this post:
Stepside66 (10-29-2020)
Strangely enough pin 48 is empty on my harness. I have no issue adding one in at all but now Im baffled as to how the Escalade tach worked? It must have grabbed signal from somewhere else? Im still going to try it unless someone comes up with some other info that makes more sense. Damn im getting closer by the minute here.... its only been a year and a freakin half got carried away on it though... Pretty much a new car now
