LS 2 clearences
Old 10-19-2011, 09:40 PM
672drcoupe's Avatar
Default LS 2 clearences
im building an LS2 from an 06 vette and going twin turbo. can anybody help me with piston to wall clearences, ring gap , main & rod brg clearences'
eagle rods. je forge pistons.stock crank. thanks.
Old 10-20-2011, 09:22 AM
Ls2 cruiser's Avatar
Piston and ring clearance you should get from your piston manufacturer. Some pistons are 4032 alloy and some are 2618 and have different expansion rates. Conrod should be .003" and mains should be .002".
Old 10-22-2011, 12:01 PM
hymey's Avatar
the most important thing is bore finish and torque plate honing, the last engine I built runs no baffles in rocker covers and just small breathers does not breath a drop filters are dry nor use oil as i chose a machinist that new what he was doing 99% of breathing issues is related to bore finish, it has to be a very fine cross hatch the more shiny the bore the better lol should look like a mirror, its harder to do with low nickel content in bore (will never look like a motorbike bore). She wont breath and push oil everywhere if its not right, if the bore is to coarse it will hold oil in the cross hatch and get past the rings, breathe and burn. You can go wide on the ring gaps and a little looser on bore clearance and still not have breathing issues. I see race engines 15:1 comp with near 30 thou ring gaps and 8 thou plus ptb clearance and have good leak down numbers and no breathing or blowing oil out rear mains. there like this as they sit on 8500 rpm constantly but have no issue at all so dont stress on ring gap just follow recommendations from the ring pack and get a good competition hone.
Old 10-22-2011, 06:46 PM
DAVESS02's Avatar
I'd go .002 on the rods and try for .0015 on the mains as the block grows when warmed up. Mine ranged from .0012 on the front to .0017 on the rear. Whatever JE recommends on the pistons, go with it. F.I., I'd go at least .024 on the top and .026 on the second. My Wiseco pistons called for .004 and I went .026 and .028 on my rings. Havent put the supercharger on it yet. Just NA for now.
Old 10-23-2011, 11:27 AM
672drcoupe's Avatar
talked to my engine builder and he said he can do that . thanks for the imput
Old 10-23-2011, 11:28 AM
672drcoupe's Avatar
found specs for my pistons. i will use that thanks
Old 10-24-2011, 06:19 AM
noice's Avatar
...related to bore finish, it has to be a very fine cross hatch the more shiny the bore the better lol should look like a mirror...
Shiny is not better the only time it is better is on max effort drag cars. Not on a street car, a proper crosshatch hone that has had the edges from honing broken down just a bit is ideal on the street.
Also you MUST properly hold oil on the cylinder wall or suffer bore wear.
As mentioned before the manufacturer will supply a card with the pistons that give you the spec for boring them. Going turbo is going to dictate different clearances on the piston and rings.
Quick Reply: LS 2 clearences
