5.3 w/ F-body pan... which oil pump o-ring?
Old 10-19-2011, 10:46 PM
austindub's Avatar
Default 5.3 w/ F-body pan... which oil pump o-ring?
I am putting an F-body pan on my 5.3 with a stock truck oil pump. Do I match the oil pump o-ring to the F-Body pickup tube, or to the truck oil pump. I purchased an o-ring for an F-body not even thinking that I might have to match it to the truck pump vs. the Camaro pickup tube.
Old 10-20-2011, 02:02 AM
socal's Avatar
they should be the same but im running the same thing w an o ring that fits the f-body pickup
Old 10-20-2011, 02:44 AM
01ssreda4's Avatar
It goes with the pickup tube, pumps should be basically the same.
Old 10-20-2011, 11:05 AM
QuickSilverNA's Avatar
The blue Oring from GM is correct. If you purchased one for an Fbody then you will have the correct piece.
Old 10-20-2011, 08:11 PM
austindub's Avatar
Thanks guys, looks like I made the right choice.
Quick Reply: 5.3 w/ F-body pan... which oil pump o-ring?
