Spark Plugs and Steam Vent hose
Just a couple quick questions
just got my 97 s10 running and
1) was curious to know what spark plugs should i use
2) does the steam vent need to be on the pressurized side or can i run it to the coolant overflow?
1997 s10
2002 6.0l
t56
TSP V2 cam
everything else is pretty much stock
Edit I answered my own question with the steam vent now i am just curious as what plugs to run.
1997 s10
2002 6.0l
t56
TSP V2 cam
I run mine to the Radiator. The aftermarket Alum radiator that I have had a threaded port that was just below the Radiator cap (not the overflow) and in the tank.
other options have been the upper radiator hose (using a Tee), Water Pump (as already stated) and also the Heater Hose (using a Tee), along with the Radiator.
