TC Lockup Woes...
Old 10-20-2011, 12:47 PM
SoxXpupPeT's Avatar
Default TC Lockup Woes...
My friend has a 93' Camaro with boltons and a tune. The other day we were driving and it seemed that the TC wasnt locking up. Cruising at 60 it was around 2k rpm (stock gears and TC)... I had him lightly press on the brake while still on the gas and it didnt do anything. that usually diactivates the lockup in my impala and caprice.
How can i go about testing to see whats wrong? There isnt a check engine light on. Would a scanner show a code at all?
Old 10-20-2011, 01:36 PM
LS1Tech Sponsor
performabuilt's Avatar
Was the car at operating temp above 130 degrees if not or if the engine temp sensor is bad you will not get lockup. Also engine missfire will disable lockup and may not set a code in either case.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 10-20-2011, 01:42 PM
lt1-xjs's Avatar
Your test would indicate it is not working properly. Scan for codes, 37 is the brake switch stuck off and they have been known to fail. Next make sure the plug on the trans is connected, beyond that a solenoid or the tcc itself. The brake switch is the most common problem.
Old 10-20-2011, 04:25 PM
SoxXpupPeT's Avatar
Thanks alot for the responces guys! Ill see what i can find and hopefully thatll fix it. Thanks again!
