Installing 2010 Camaro Brembos,,, a few questions.
Im going to be installing my SLP sourced 2010 14" brembo's soon and i have some questions. I know someone did a write up on the camaro brembos specificly but i cant find it. Anyway...
I have 18" C5 Magnesium wheels all around, I know i need to run a small spacer in the front to clear the caliper, but i dont know what length arp wheel studs to buy (through searching on the forum there is even argument as to what length is on the car stock!). Also, who is the best source for brake lines?
alittle off topic,,,but can you please post a pic of the C5 magnesium 18's on the front of your car.
I have the same wheels ,,but 17" front 18" rear,,and have thought about going with 18's all the way around.
KORE3 on the lines. flynbye used to do it but I coudn't get ahold of him. He is ebmiller on here. You could try either. KORE3 hooked me up good though, front and rear. I will do some digging and see if i can find the studs i used.
Almost positive they were these.
http://www.jegs.com/i/JEGS+Performan...65131/10002/-1
When I went to order the ARP's they were sold out at jegs and summit so I went with these jegs brand. Measure your stocker length first tho. I narrowed it down to these because they are the only metric set of studs jegs offered so it had to be these. They don't have another length.
