Drag Racing Results - 14 flat in my GTO :(
View Full Version : 14 flat in my GTO :(
chevbon
10-21-2011, 11:53 PM
So going into tonight, I was expecting to rip off at least a 13.7, probably somewhere closer to 13.4. I have an m6 LS2 GTO w/ catback and intake. Got there and couldn't break into the 13s... I guess maybe it could have something to do with my tires being close to needing replacement in the rear? Still figured after that I should have been in the 13s with all the wheel hop. I was at cecil county which doesn't have too high of a reputation for track prep.
GTOSE
10-22-2011, 02:34 AM
Invest in some drag bags (mad cheap) or suspension, tires are definitely important, unfortunately it's big bucks to get a bigger tire on these cars.
chevbon
10-22-2011, 12:38 PM
People have been telling me that and to just go with a solid axle. What's your setup look like?
mrbigjeep
10-23-2011, 03:28 PM
sixty foot?
SSPerformance
10-23-2011, 03:37 PM
you should be able to hook at cecil ... post up ur time slip
chevbon
10-23-2011, 05:05 PM
My best was 14.012 at 103.4
60= 2.418
330=6.167
1/8=9.230 at 80.71
1000=11.825
MasterTomos
10-23-2011, 05:11 PM
^60' is a huge issue. Get it to hook/launch harder and you should see some better times.
chevbon
10-23-2011, 05:14 PM
I'm due for a new set of tires too. I was launching a little over 3 this time, does 4 or 5 sound better? Thinking about getting some drag radials and a set of drag bags and trying again in the spring...
yelo04goat
10-23-2011, 05:21 PM
don't need huge tires.. wheel time and some good sticky tires.. i used mickeys bias ply 17s
you don't need solid axle either...
spicebird98
10-24-2011, 01:35 AM
4-5k??? That's way too high on street tires. Try leaving just off idle at 1200 or so, maybe even less and slipping the clutch.
WayFast84
10-24-2011, 03:09 AM
Get that sixty to 2.00 and its a 13.2 slip. In comparison my 99 with a lid went 14.4 at 104 with a 2.6. Good luck.
3rdgen92maro
10-24-2011, 10:27 AM
just invest in some 275 MT Streets for the stock wheels. I ran a buddy of mines 06 m6 car with TIRES ONLY and it went 13.2@106 with a low 1.9 60'. I was leaving around 5-5500 and it hooked without any issue at all!
Smo's04Gto
10-24-2011, 10:32 AM
With a 2.4** 60' you need alot more seat time at the track. These are not the easiest car to launch.
fattydre
10-24-2011, 11:27 AM
That's worse then fwd cars 60'. don't expect a lot your first time out, your times will increase with seat time. With your trap you definitely have mid-low 13's in it.
Best thing you could do is get some drag radials.
ROMERO98Z28
10-25-2011, 03:19 PM
its not the car, its the driver and the tires!
chevbon
10-25-2011, 03:38 PM
Im convinced its my tires, I only ran .3 better than my LT1...
ROMERO98Z28
10-25-2011, 11:53 PM
time for some new tires bro for next year! well my home town track is close for the winter
