HELP 02 Camaro V6 to LS1
You only need to pick the engine you want. New engines mounts, new or used wiring harness modified, new trans traverse, new output shaft, new rear end, t56 6 speed manual, new radiator, new hoses, electric cooler, new flow tank, new fuel pump, new exhaust and it goes on and on. Just did it for a customer, he had the 2,8 v6 and upgraded to 383.
Everything you need for parts numbers and what not are listed in the GM F-body Factory Service Manual.. Since this is nothing more that a factory upgrade from a V6 to a V8. You will find many have done it and posted there thread of doing it one way or another.
Many well just tell you to just buy a V8 car.. and avoid the work as the V8 cars are getting pretty cheap now.
If not, get a Donor car and pull everything out and transfer it into your V6 car. That way you will have every thing.
Hmm buy a V8 car just to strip it and put it all in to another car ? seem like a lot of work for what you end up with (cost wise)... wow, I coulda had a V8.. !
I looked into this 2 or 3 years ago and to do a good complete swap the only affordable way to do it would be with a complete V8 donor car, and i'd have to be one hell of a deal for you to come out ahead of just trading you v6 in for a v8.
