Need Cam Spec? Help Mamo
Old 10-22-2011, 11:57 AM
02-ws6-6speed's Avatar
Default Need Cam Spec? Help Mamo
Below are my numbers/mods on my car. Tony Mamo told me he could custom spec me out a new cam that will work better with my setup but can you tell me how much more horsepower is to gain with a custom grind cam? Hopefully Tony Mamo will see this thread and respond but any opinion is welcome. Also, I am still running stock lifters. Will aftermarket Yella Terra or Harland Sharp make any HP difference or help my motor?
2002 TRANS AM WS6-M6
Stock Bottom End 346
Stock 3.42 Gear
Kooks Long Tubes
Y-Pipe no cats
Borla Exhaust
Powerbond 25% U/D Pulley
MSD Wires
NGK PLugs
K & N Filter
Comp Cam .644 lift 231/234 113 or 114 LSA (Friend has spec card)
7.400 Comp Pushrods
Extreme .650 lift springs and Titanium Retainers on Stock LS1 241 Heads
Stock LS6 Intake, Stock T/B and Injectors
SLP Lid and Bellow
Dyno HP Tune
406 RWHP 386 TQ
New Mods
AFR 215 Mongoose Heads
Fast 102mm Intake
Fast 102mm T/B
Texas Speed and Performance 100mm MAFS
Fast Toys 104mm Lid
Fast Billet Fuel Rails with Ford 42# green top injectors
Racetronix Fuel Pump/Power Harness
Tick Performance Master Clutch Cylinder
Hypertech 160° Thermo
Dyno HP Tune
470 RWHP 415 TQ
Old 10-22-2011, 11:15 PM
Flow Wizard
Tony Mamo @ AFR's Avatar
The key to really being able to select the right cam lies not only in the right specs for the overall application (engine and type of vehicle usage), but also in knowing exactly how effective the cylinder heads are, what they flow, and more important than peak in some respects, what they flow down low which should effect your decision concerning LSA and installed position.
Obviously that gives me a leg up on how to grind a custom cam, especially concerning an AFR cylinder head.
Just some input I thought was worth sharing....
-Tony
Old 10-23-2011, 08:09 AM
vettenuts's Avatar
Between Yella Terra and Harland I would go with the Yella Terra's. They will help with valve guide life and will provide much better geometry. Make sure you set geometry first and then measure for pushrod length. There will be minimal hp gain, the gain is in a proper geometry.
Old 10-24-2011, 01:14 PM
Rise of the Phoenix's Avatar
470 rwhp and 415 rwtq are pretty impressive.
Old 10-24-2011, 03:22 PM
Samer's Avatar
I would like to see your dyno numbers after swapping the cam.
Old 10-24-2011, 04:46 PM
Tony, How do I find out all this info you need to know? Does AFR Flow Test all heads before they ship? Please help. If this will gain me more than 10-15hp, I would like to do it.
Old 10-25-2011, 11:55 AM
chrs1313's Avatar
anything in the upper 23x/lower 24x on a tighter LSA will give a decent gain over the current cam you have now...
Look at all the bigger cams out there and you will see most specs are in this range...
ms3, ms4, polluter, si6 or si7, raptor, vindicator, etc...
or even a custom like i have 239/243 111+4 lsl/lsl .624/.624 basically hybrid ms4ish cam
Old 11-02-2011, 05:49 PM
What do you consider a descent gain? number????
Quick Reply: Need Cam Spec? Help Mamo
