Tire size issue
Old 10-22-2011, 12:06 PM
jm01z28's Avatar
Default Tire size issue
Have an issue here with my tire size on my stock 2001 Z28, running on 245/50/16.
I want to replace the tires as the same original size but the issue is I am not able to find the same sizes in where I live (United Arab Emirates)
I am thinking of 1 of 2 options
1) keep the 16'' size but change the 245/50. Can someone suggest what size to use without messing with the drive-ability / handling of the car?
2) go with 17''. Again what size should I use?
I don't want to mess with the wheel sensors coz I've read that changing the tire size may affect the wheel sensors...
Any other suggestions?
Old 10-22-2011, 12:48 PM
carlos64030's Avatar
A 275-40-17 will be the same overall diameter as your current tires.
Old 10-22-2011, 01:30 PM
jm01z28's Avatar
Will the size you suggested fit on a 2001 17" SS rims?
What other sizes can I use with the 16" that will still give me the same overall diameter?
Thanks.
