Custom built T56 32-spline SSR/Ford/LS1 F-body Hybrid
Old 10-22-2011, 02:56 PM
TDP
TDP's Avatar
Default Custom built T56 32-spline SSR/Ford/LS1 F-body Hybrid
This is a Ford aftermarket tailshaft housing. It came on the aftermarket "conversion tranny" for the Fox body Mustangs. I'm only using this housing because I got a deal on it. Otherwise these housings cost well over $500, and wouldn't be an option! It comes with the provision for the Ford manual speedo cable and/or Ford elec. speedo, which is going to be changed to GM electric speedo. Also, notice how long the housing extends out. 1.25 inches is going to be removed from the end of the housing, so it will match up with the f-body length. Then it will be bored to fit the TH400 bushing and seal. This will allow the 32-spline mainshaft to be used. Also, the shifter location will be moved back by using the Ford setup, 3inches (from centerline to centerline).
Here it is just as it comes, untouched..
Driver side
Passenger side
Top (31-spline in stock form)
For comparison, here is the stock f-body tailhousing (side view)
Top view
GM Elec Speedo Conversion
Close-up
New height of tailhousing, and speedo sensor installed
Ford elec speedo sensor, plug installed
Close-up
TH400 bushing/seal installed, for 32-spline SSR mainshaft
Random 31/32 spline conversion parts....
32-spline shaft compared to stock
31-spline yoke
32sp slip yoke compared to stock
31-spline yoke
31-spline shaft w/ press-fit speedo journal added
Close-up
31-spline shaft installed in trans
Old 10-22-2011, 09:27 PM
thesource's Avatar
Thats a hard tailhousing to find. I have a couple of them myself.
Old 10-22-2011, 11:02 PM
TDP
TDP's Avatar
I actually have 2 more of them. I'd like to trade one for an OEM 03-04 Cobra one if you are interested or if you know where one is
Quick Reply: Custom built T56 32-spline SSR/Ford/LS1 F-body Hybrid
