Clutch Sticking to Floor
Old 10-22-2011, 09:10 PM
02-ws6-6speed's Avatar
Default Clutch Sticking to Floor
02 WS6
I went to the track and could not get my car into 3rd gear and the clutch needed to be pumped every time I punched it. I was told to change out the slave cylinder and master clutch cylinder. I did and now I can get into third but the clutch pedal still sticks and I have to pull it up with my foot and pump the pedal to get pressure back. Please Help. Whats the problem.
Old 10-24-2011, 01:25 AM
meine96ws6's Avatar
How does your fluid look? I would try to flush it and go from there.. is it only under "hard" operation/ high rpm shifts?
Old 10-24-2011, 09:18 AM
SPEC-01's Avatar
Flushing and refilling the system is a good suggestion. Additionally, did you do the drill mod on the line that leads from the master to the slave cylinder?
Old 10-24-2011, 02:41 PM
SNLPerformance's Avatar
I assume this is the stock clutch giving you problems, how much power is the car making?
Old 10-28-2011, 06:55 PM
Fluid looks a little dirty and yes only under high rpm. I did not do the drill mod because I thought the Tick Performance part would fix this problem. Yes it is the stock clutch and the car makes 550 hp and 470 rwhp.
Old 10-29-2011, 07:55 AM
djfury05's Avatar
get the Tick Master Cylinder
Old 10-29-2011, 09:39 AM
94 s dime's Avatar
That clutch is probably hating life being stock with that power, my car made 400 on ls6 clutch and it sticks occasionally.
Old 10-29-2011, 03:41 PM
Yeah you've definitely exceeded the power of the stock clutch and need to upgrade to something that can handle it. A Monster Level 3 would be my recommendation and give you power to grow. Feel free to contact me with any questions. Chris, 817-750-2000
Old 10-31-2011, 09:18 AM
LS1TECH Sponsor
Joey@Tick's Avatar
Yikes! Definitely time to upgrade that clutch. While you're in there, upgrading the master cylinder, replacing the slave cylinder/throwout bearing/pilot bearing is a good idea, as is installing a Remote SPEEDbleeder Line. Luckily, we offer a Tick & Monster COMPLETE Clutch Swap Package that includes everything at a discounted price: http://www.tickperformance.com/ls1-f...-swap-package/
...and yes, our Adjustable Clutch Master Cylinder Kit eliminates the need for the drill mod, as it includes a stainless braided, heat-wrapped unrestricted line, seen here: http://www.tickperformance.com/tick-...or-ls1-f-body/
Best of luck!
Old 11-01-2011, 01:44 PM
RUQWIKR's Avatar
Emailing you now about a clutch...
Old 11-02-2011, 05:48 PM
i already bout the tick master clutch cylinder and replaced the slave cylinder before I bought the Tick Part. I guess its time to buy a clutch.
Old 11-04-2011, 09:19 PM
Cooldude5231's Avatar
no sounds like you didnt get all the air out of the lines.
try re bleeding the system
Quick Reply: Clutch Sticking to Floor
