LQ402/8 with ls3 heads- Compression Ratios
people that are running LQ402/8 with ls3 heads...
can you please post your Compression specs
1-heads are milled to?? (if not stock 70cc)
2-thickness of head gasket??
3-type of piston??
4-Compression Ratio??
just want a general idea
3-type of piston??
Yes I live in Las Vegas where it's hot as hell and I run 91 octane. 435hp and 400ftlbs through a 4L80e in a truck. The tune was complete **** so I need to head back to the dyno soon. I bought HP tuners cause I thought the tune was way off, and man I was right. Hoping to get at least another 30hp out of it. I used all stock components in my build with a 231/239 cam as a starting point.
