Western Members CA, AZ, NV, UT, CO, NM, HI
Can anyone help me with my car issue?
Old 10-23-2011, 01:57 PM
danielisradd's Avatar
Default Can anyone help me with my car issue?
I took my 2002 camaro z28 into selman chevrolet in orange california.
When i arrived they did a diagnostics on a cat converter warranty repair. My only signal light was for the cat.
On receiving my car, here are the gauges that dont work: rpms, gas, oil pressure, temp. abs in op, air bag in op, traction in op.
Any ideas of what is going on? they said they will not cover it even though it happened when it was with them over night.
cats are bolt on so they said they could not have caused it. I only went to dealership because it was a warranty fix.
Thank you. Or if you know anyone at that dealership that can help me let me know . thank you.
Old 10-23-2011, 03:59 PM
MeenZ28's Avatar
Check the fuses?
Old 10-23-2011, 04:28 PM
MikeyZ's Avatar
sounds like the signal wire from the computer to the gauges has been cut
Old 10-24-2011, 01:14 PM
thanks its getting looked at today
Old 10-24-2011, 10:31 PM
mannyman84's Avatar
Any luck?
Old 10-25-2011, 07:22 AM
SS4Luck's Avatar
Daniel, your a McDouche!!!!
Check your other thread, send me a text when you see these, one of the guys at work has an idea
Quick Reply: Can anyone help me with my car issue?
