oil pump install... assy lube, vaselene or ???
Old 10-25-2011, 06:33 PM
Jim85IROC's Avatar
Default oil pump install... assy lube, vaselene or ???
Back in the good old days, guys packed oil pumps with vaselene to help prime them. To me, that doesn't seem smart. Until things get hot enough to melt the vaselene it seems like it could prevent oil from getting into tight areas. I'm thinking about just coating the inside with assembly lube. Opinions?
Old 10-25-2011, 06:53 PM
kwiksilverz28's Avatar
If all you are doing a pump install on a running motor, just make sure the pickup tube o ring is in right, finish install, and crank it up. I have done a ton of cam installs with pumps, and have oil pressure in a couple seconds....
Old 10-25-2011, 07:11 PM
S10xGN's Avatar
I've always used Vaseline on motors that cannot be easily primed, no problems here...
Old 10-26-2011, 08:04 AM
Jim85IROC's Avatar
Pump is going on a brand new motor for what it's worth.
Old 10-26-2011, 09:19 AM
99LSS1's Avatar
At my buddy's shop we coat the gears with some clear sticky lube, Can't remember what it is called. I think assembly lube would work fine.
Old 10-26-2011, 05:32 PM
vettenuts's Avatar
I used Redline Assembly Lube, which dissolves as soon as oil hits it. The pump would actually suck air when slowly turned when I installed it like this.
Old 10-26-2011, 08:29 PM
Jim85IROC's Avatar
I think I'll just go with the assembly lube. I just don't like the idea of pushing vaselene through the motor. It just seems like it could prevent oil from getting to things until it melts away.
Old 10-26-2011, 09:43 PM
noice's Avatar
While I wouldn't use vaseline in the pump, it is a positive displacement pump, which means it will move a fixed amount of fluid (air, water, oil, grease) per rotation. It will prime itself and pull the air out of the pipe, the only way it wouldn't would be if the pump rotor/gear was so worn out that air could recirculate from the discharge side to the suction side and short circuit the pump.
The point is, that pump will suck that vaseline through it like **** through a goose. Sure it might place extra load on the pump, but it'll move it.
Old 10-26-2011, 09:54 PM
Jim85IROC's Avatar
It's not in the pump that I'm worried about the vaselene, but downstream in the filter or in smaller passages.
Old 10-26-2011, 10:06 PM
noice's Avatar
Well if you are worried, just take some vaseline, put it in a cup full of oil and mix it up for a bit, see if it breaks down.
Old 10-27-2011, 12:00 AM
pairof69s's Avatar
i'm with ya on this.........I would think assembly lube would do the trick
Old 10-27-2011, 07:24 AM
O2Form's Avatar
All that is necessary is to pour a small amount of oil in the pump before you mount it.
Old 10-27-2011, 09:56 AM
Fastdriver1992's Avatar
agreed, have done plenty of motors this way
Old 10-27-2011, 05:28 PM
Jim85IROC's Avatar
Thanks guys. If all it needs is a little oil, then I can't imagine any harm in using assembly lube when I put the pump back together.
Quick Reply: oil pump install... assy lube, vaselene or ???
