i want a cam for more top end
Old 10-25-2011, 06:51 PM
regency's Avatar
Default i want a cam for more top end
Since ive had this 228R ive always wanted a bigger one, and have always thought about the MS3 or similar. Soon i will be pulling the motor and freshening it up, and that would be a great time to swap the cam.....
I am running 4.88 gears and 29.5" tires, and i want to rev it more because of the low gear ratio. I will get ARP rod bolts so i can rev it more. Right now im shifting at 6400 and it seems to act like its short shifting. I mean it runs great and has lots of HP/TQ, but i just want a few more tenths out of it.
Just looking for some opinions here!!
Old 10-25-2011, 07:25 PM
99Bluz28's Avatar
How many degrees of advance is ground into your 228r cam?
Have you considered retarding it a couple of degrees, that would move your power band up.
Old 10-25-2011, 09:47 PM
Captain Double Post
BOBS99SS's Avatar
What heads are you running?
Old 10-25-2011, 10:23 PM
MIKELMOTORCYCLE3398's Avatar
236/242 112lsa Do what lift u need. Mine is .580/.590. Top end out the ***
Old 10-26-2011, 08:31 AM
regency's Avatar
Running ported and milled (.012) 243's, never been flowed. I also have .040 cometics which i will go back with.
Old 10-26-2011, 08:33 AM
thunderstruck507's Avatar
Have you had it dynoed? Tried shifting higher?
You could be short shifting.
Old 10-26-2011, 02:25 PM
regency's Avatar
Yes i have a thread for it, was like 427/403 and peak power 6400 and shifted there.
Old 10-26-2011, 04:24 PM
If peak power is 6400 you will be faster shifting several hundred rpm later. How much later depends on where it really falls off hard.
