turbee or not turbee
first off,the car is a ls1/4le60 swapped 240sx, running on a 3800 stall, 100 wet shot,4.10 gears and full weight (2900) other than that is all stock.
my goal is to get somewhere in the range of the 450whp and make it last,i know that i can make such a "low" hp figure on motor, but with far west texas weather and 3800 ft above the sea level,before i even notice im gonna be w/o 3k in my pocket and 450 hp or so and still unhappy
tunning and fabrication is already in mind,my plan is to use truck manifolds and ls1edit for tunning.turbowise im thinking in a turbonetics T72 or something in that range (i want to do a single turbo because of the space in the chasi)
also i want to keep it below 10 psi,just to be on the safe side,because i dont want to blow this thing ....yet..
is this plan seems to be complicated for such a low goal? i dont plan to use cheap parts, but im gonna try to do all the work myself so i can save some $$, i want the setup to be very responsive since i dont think i'll rev it over 6k,is this turbo ok, for that??
thanks
thanks
Turbee? Really?
You're going to use LS1edit? I'm not familliar with that software package, but do they have 2/3 bar operating systems like EFI Live and HPT? To "make it last" you'd want to have full control over your fueling.
i plan to run low boost,so i think the stock map sensor should do ok(a have a speed density tune btw),i have played with turbos before, but it was with imports,so for this engine i just plan to take some timing out and build a solid fuel table....the bad think is that i have no experience with ls1edit, so i might have to ask a friend to tune the car for me, or maybe just take it to somebody else, we'll see later,the first thing is to get it running
That explains it....lol.
I would stay away from LS1edit for tuning a turbo LS. I know a lot of guys who tune LS engines, myself included, and nobody uses Edit anymore...
EFI Live or HP Tuners is where you will find the most support, and the most control over a stock GM PCM
