L.E.D experts come in please
Ok so I took my gauge cluster out and I have a l.e.d gauge face and I accidentally tore the lead going in to the face is there anyway to fix this? Can I solder that piece back together it's just a small tear on the little copper looking piece and a little above it so can I fix this or am I screwed?
http://s1192.photobucket.com/albums/...nt=photo-9.jpg
http://s1192.photobucket.com/albums/...nt=photo-8.jpg
Copy & Paste Moderator
You can probably fix it by soldering it back together. Couldn't hurt to try. The copper probably has a clear coating that you'll have to sand off around the tear to get the solder to stick and make a good electrical connection.
If you are careful, you won't melt a diode. A staple will probably be a loose / weak connection even with silicone and will probably eventually fail.
