What harness for LM7 to have ecu under glovebox?
Im swapping my engine out for an Lm7 this winter and I want to have the Ecu in the glovebox.
I need to run the car with the std lambdas, Egr and o2 sensors. What wire harness will be most easy to use? Maybe itīs most easy to buy an aftermarket wireharness?
Can I use any Ecu that comes from an Lm7 engine wich is drive by cable? The enginge I have found doesnīt come with any harness or ecu.
LS1Tech Sponsor
You can use any PCM that supports drive by cable to run the engine. We have a harness that will put the PCM and Fuse/Relay center in the glovebox. Cost is $499.
Jon
PSI
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
