1998 WS6 Full top end build tons of mods
Year: 1998
Make: Pontiac
Model: Trans Am
Price: $9950
Mileage: 152000
Private or Dealer Listing: Private Listing
Location (State): TX
Color: Black
Transmission: Manual
LS Engine?: Car has LS engine
Make: Pontiac
Model: Trans Am
Mileage: 152000
Color: Black
Super clean vin, available on request, taken to dealer for servicing every 3000 miles, no accidents. Not hot rodded, only 2000 miles on the build, taken to the track twice after appropriate break in miles. Dyno'd 355hp/362ft/lb BEFORE heads, cam and manifold install, have not had it to the dyno since, but def makes much more now, with a proper tune will make even more. Super tight handling, NO tranny rear end noise, drives like a dream. $10,000+ in parts already installed, less work for you. This needs to sell.
mods-
For pics go to http://98ta4sale.webs.com/
Engine-
Fast 102mm intake/throttle body
Fast fuel rails
Racetronix 42lbs/hr injectors
msd wires and coil packs
AFR 225cc mongoose heads w/PRC .675 double springs
ls7 lifters
harland sharpe rocker arms
Racetronix warboro fuel pump
Underdrive pulley
AC system removed
TSP MS4 cam (.649/.609 239/242)
American Racing Headers/cats W/electric cutout(elect switch in place of tcs button)
hooker muffler
hi-torque starter
Drivetrain -
Master rebuild kit on tranny from thegearbox.org
(syncros bushings shift forks seals and bearings)
3:73 rear gears
hurst short throw shifter/short stick and black hurst ****
McLeod Clutch master cylinder
Ram Heavy duty clutch
Billet steel flywheel
suspension -
QA1-R adjustable front coilovers
QA1-R rear shocks
subframe connectors
poly tranny mount
solid tube motor mounts
EBC slotted rotors on the front
EBC redstuff ceramic pads front and back
Issues - mail order tune not perfect which is causing small power loss and idle issues - idles high in open loop, does not powerband as big as it should, dyno tune will fix this, texas-speed does mail in for 225$ and inhouse dyno for 300-400$ last time I checked.
Receipts and detailed description of every performance part installed available on request and will be included upon final sale of vehicle.
