HelP!!!
HelP!!!
This car is driving me nuts. Car will not stay running fires then dies vats was removed by cms also barro map tune installed I was able to get it to run for awhile feathering the throttle. Car has good feul pressure and computer has constant power. I'm lost car sounds great with initial fire then something changes
70 camaro
Lq4 with th400 trans
60lb injectors
Barro map
Sd tune from cms
Car sound good on first fire then shuts down I was able to het it to run barley once has cOnstant fuel pressure and ecu has power
60lb injectors
Barro map
Sd tune from cms
