steering issues
steering issues
I have a 99 z28 m6. I ve 100k on it and i have two steering issues that are driving me crazy. (no pun intended) anyway first prob;em is my steering wheel has a little bit of side to side slop. maybe 1/2 inch. I wanna get that out of there and was wondering if i can adjust it at the box bc thats where its at. 2 next problem is the pin on my column is worn bc if i pull hard enough the steering wheel moves, i ve done it launching the car once or twice. Is their an easy way to fix that or do i need to replace the column. thanks for the help
for the play in the steering wheel check you inner and outer tie rods. do this by jacking the car up in the front and while looking the tie rods try too move the tire from side too side if you see the outer tie rod move up and down or the inner move in or out replace them. of the steering wheel moving up and down there is a bushing kit you have too buy and there is also a special tool too press the pins out.
thanks man. didnt even think to check them. It feels like its in the box but i ll check the tie rods. any one got advice on fixing the steering column to keep it from dropping
