6.0 performance cause emissions problems?
im doing a swap of a 6.0 iron block into my 85 el camino, im a little new to the ls engines...im wanting to do some mods to the engine, but problem is it will be a daily driver and i will have to pass DE exhaust emissions, and i dont plan on taggin as classic either. i wanted a cam for the engine but will it be out of the question for emissions?
it will be an iron block 6.0, forged pistons (either .010 or .030 over), everything else is stock from a truck untill i start upgrading. will have some f-body headers, duals with dual cats, and i will make an intake for it. probly 4l60e trans...dont like manual trans.
im doing this engine without putting in WAY too much money. so im asking if anybody has some input on some emissions issues with add ons, or possibly some add ons to help get some good HP to the wheels?
Moderator
You can still run a decent cam and pass emissions by putting a set of CAT's on your car and tuning the car by leaning it out and running a 50/50 mix of denatured alcohol....how do I know this...I did this when I had a forged LS6 in my car with a lumpy 236/236 cam and made 440RWHP to the wheels while passing the sniffer at the tailpipe
I'm curious what cam you used and did it pass the sniffer?
Did you make a couple attempts at the test or pass the first time?
Moderator
How lean are we talking?
