94 383 SBC to 5.3 PT76 Build Thread
Old 10-27-2011, 09:22 PM
Strokinit383's Avatar
Default 94 383 SBC to 5.3 PT76 Build Thread
First off, thanks to everyone who has provided their input to get me this far. I figured I would start a build thread. Unfortunately, all of my before pictures are in external hard drive heaven. The car started as a 94 3.4 v6, to which I swapped in a 383 sbc/t56. I sold that setup last year and began working on the current setup...
Budget 5.3
Precision T76
Tial 44mm wastegate
RPS 50mm BOV
Ebay intercooler
224/228 @114 cam and upgraded valvetrain
ARP rod bolts
LS7 clutch....for now
Anyways, here are the pics so far:
The 5.3...$400 bucks at 70k miles
motor pulled...waiting for its new powerplant
I began to clean up the front end...removing the rust and laying down some primer.
Notched out front frame for vertical griffin
<a href="http://s1227.photobucket.com/albums/ee438/CI-V-IL/Camaro%20Turbo%20LS1%20Conversion/?action=view&amp;current=1209.jpg" target="_blank"><img src="http://i1227.photobucket.com/albums/ee438/CI-V-IL/Camaro%20Turbo%20LS1%20Conversion/1209.jpg" border="0" alt="Photobucket"></a>
Repaint
A few brackets to help support the radiator
Block cleaned up and painted
Primed and painted the intake manifold and valve covers
Some more parts cleaned up
Repainted rails
Tap for the feed and drain
Started cleaning up my old firewall heater box plate
Cobalt MAP sensor installed
Cleaned up the truck manifolds
Mounted the intercooler
Began preparing a few things for the wiring
Clutch and flywheel on
Coming together
More to come!
Old 10-27-2011, 09:30 PM
Sorry for weird picture sizing...must be something with my phone.
Old 10-27-2011, 09:49 PM
Oh yeah....and the goods
SJM ABS Delete
Old 10-28-2011, 09:11 AM
Larry @ AMS's Avatar
looks like a pretty nice build
good work
Old 10-28-2011, 12:13 PM
navyblueSS's Avatar
Nice build!
Old 10-28-2011, 01:33 PM
Fbodyjunkie06's Avatar
Hell yea man good solid part list and looks like you got a good build plan.
Old 11-01-2011, 07:14 PM
Finished up the heater plate. Double layered the sound/heat deadener on the back.
Got the engine/k-member in. Camera didnt focus very well. I will get some better pics tomorrow.
Much easier going in underneath!
Old 11-02-2011, 01:39 AM
TX RED's Avatar
Nice build
Old 11-02-2011, 04:17 AM
Fb0dy0nly's Avatar
lookin good so far, I like the extra time spent cleaning and preparing everything first.
I was thinking this was going to be a track car but I see you fitting the bumper support plastics, whats your plan/goal with this thing?
Old 11-02-2011, 07:44 AM
Originally Posted by TX RED
Nice build
Thanks!
You're exactly right. I'm not building a max effort track car here. I just wanted something that was fun, looked clean and was "somewhat" affordable. I wasnt sure how much the front bumper cover would sag without its support, so I tried my best to keep everything intact. I'm gonna see what this 5.3 will take. I have an LQ4 waiting patiently for its demise.
Old 11-02-2011, 09:25 AM
RealQuick's Avatar
What radiator and fans are you using?
Old 11-02-2011, 09:37 AM
RealQuick - Im running a vertical griffin and two 12" puller fans. They are supposed to move 1200cfm a piece. I'm not sure if they would have the juice to run as pushers, but they should do the trick as pullers.
Old 11-02-2011, 09:48 AM
RealQuick's Avatar
Remember the P/N's of the radiator and fans?
Old 11-02-2011, 09:57 AM
Radiator was from summit - GRI-1-25241-X
Fans were from Jegs - 555-52131
Old 11-02-2011, 05:15 PM
jfg429's Avatar
looking good!!!
Old 11-11-2011, 11:34 AM
Ive been working on the hot side the last few days. Some progress pics:
A bunch of room for the downpipe. I could have easily ran a 4" pipe.
The hot side
Old 11-11-2011, 11:38 AM
More pics
I painted and wrapped the hot side. Reinstalled it and began putting the cold side together.
Old 11-11-2011, 12:11 PM
Last few
Old 11-14-2011, 08:15 AM
Are you guys doing anything special with the vacuum line that runs to the brake booster? Right now mines routed straight from the back of the intake to the booster.
Also, does anyone know what size the drain plug is on the bottom of the griffin radiator?
Quick Reply: 94 383 SBC to 5.3 PT76 Build Thread
