TC78 fitting sizes
TC78 fitting sizes
Hey guys just had my TC78 arrive today and need to order some fittings for the vacuum hole and i need fitting sizes for the feed and drain. Can anyone help me out on thread sizes?
Also how can i tell if my turbine housing is the correct size as there is no stamp to say in it? Its brand new from Turbonetics.
Cheers Nick
Cheers Nick
I just jumped on Flea-bay and ordered the feed flange and drain flange then went from their at a local speed shop.
I still have both my flanges and -an fittings from my tc78, i cannot use them on the BWS400. i have no clue what shipping Aus. would be.
Hi Nick, I just went through the same search, that info is no where for some reason! These are the parts I used
Oil inlet 1/8npt: http://www.summitracing.com/parts/GAR-J9032/
Oil outlet: http://www.summitracing.com/parts/TNT-20259/
http://www.summitracing.com/parts/TNT-30244/
Exhaust flange: http://www.summitracing.com/parts/TNT-30241/
The vacuum hole is 1/8npt too. Not sure on how to tell A/R.
Can also get them here a little cheaper (for T4 housing):
http://racepartsolutions.com/products.asp?cat=102
The AR is cast on the inside of the exhaust inlet if I remember correctly.
Thanks fella's, found the A/R hiding inside the exhaust housing definitely 1.15
So on the oil feed fitting it has what looks to be a filter in built this should be 1/8 npt thread into it yeah along with the vacuum hole thread?
Im going to have a bit of left over -6 braided from my fuel lines is that too big for the feed or will the filter sort that out or should i go with -4 on the feed?
What size drain is best suited? -8 or -10?
Thanks again for the help, im buying all my fittings and hoses from the States so i have to be sure before ordering anything.
Maybe make some calls on this side of the pond ! Start with a few of the Sydney shops : Marrano's , Castle Hill Exhaust , Russo Performance , Just to name few.
Oil feed -4 is the norm. Oil return you want 19mm ( 3/4" ) as minimum.
