milling AFR heads
Sawzall and Welder Mod
It depends. Was the intake ported to the heads while bolted to the block you're using? If so milling the heads will have more of an effect on alignment. If it's not ported at all or it was ported independently of the heads it probably wasn't perfect to begin with.
For what it's worth, I bought a set of Ls3 heads from LPE and they milled it to 65cc's and my 102 bolted up with no problem. I don't think that would be the biggest of your worries though, I would be more worried about PTV and water pump clearances. Ive had to grind the **** out of my w/p so my N/W TB can fit.
