Difference between Crossmembers and DS safety loop
Old 10-29-2011, 12:11 AM
Ballinonabudget's Avatar
Default Difference between Crossmembers and DS safety loop
So I've got a BMR driveshaft safety loop... this one.
http://www.ws6project.com/user_stor/...safety-loop-1/
A buddy of mine just sold his car and gave me this Spohn crossmember, which says it's for longtube headers and Y pipe setups. It comes with the DS safetly loop built in.
http://www.ws6project.com/user_stor/...er-long-tub-1/
My question is, do these both bolt in the same place? And if so, which one would I be better off running, and what are the benefits of the better one? I have a 700R4 auto trans (4l60 basically), and a Edelbrock tubular trans mounted torque arm. I have Pacesetter LT's, 3" ORY, and 3" Borla catback.
From the pictures, they look pretty identical as far as mounting and all that goes, but I'm a noob when it comes to this stuff so I don't know what the crossmember has that is better than the DS safety loop. The crossmember is like 3x the cost.
Old 10-29-2011, 07:54 PM
bump...
Old 10-30-2011, 06:17 AM
Duffster's Avatar
yes, same mounting, irrelevant as to which you use. Both perform the same task. Sell the freebie and sleep well. Saves you the 30 minutes switching them out.
