IP dimmer keeps blowing fuse! no lights?
Just llike the title says my fuse for Ip dimmer keeps blowing. This first happened about two weeks ago, I replaced the fuse and was fine until yesterday. I replaced two fuses on the way to work at 6:30. Last night arounf 11:00 they went out again . any ideas are greatly appreciated.
Thanks
Spencer
Thanks
Spencer
sounds like your dimmer switch is shorting out internally. id start with that, easy to replace and cheap. if you still keep blowing fuses, then your gonna be looking for an open or short to ground somewhere else. but since its not imediate, id start with the switch
