Drag Racing Results - Three 9 sec. passes at MIR
subhumanzz
10-29-2011, 05:23 PM
Took the car out on its maiden voyage this past Friday. First pass i was just going to footbrake it and run out the 1/8th but it felt good so i stayed in it and ran it out the back. I just stalled the car up to 2k and let it rip. This was the first pass on this motor and the slip came back as:
1.45- 60'
6.44@107
10.14@133
Went back to the pits and checked everything over and drained the catch can and decided to make a full pass off the brake, results were:
1.41- 60'
6.36@108
10.05@133
Pits again and the same procedure with a slight shock and shift light adjustment. i told my buddy that was there that i didnt care if it went 9.999 i just wanted a single digit pass and i knew it was definitely there. slip came back as:
1.37- 60'
6.33@108
9.998@134
next was another suspension adjustment and:
1.38- 60'
6.34@109
9.995@135
decided to bump the light up another hundred rpms and turn the shocks back down to a 3 :
1.32- 60'
6.27@109
9.93@135
I was pretty happy for having the car out for the first time in months and also with a whole new combo. heres is a video of the 9.93 pass in and out of the car and a few pics.
http://www.youtube.com/watch?v=oE4zvvU11Lk
http://www.youtube.com/watch?v=9waar7ihPoA&feature=related
http://i37.photobucket.com/albums/e73/mahogoff/DSC_0655.jpg
http://i37.photobucket.com/albums/e73/mahogoff/DSC_0636.jpg
http://i37.photobucket.com/albums/e73/mahogoff/DSC_0657.jpg
http://i37.photobucket.com/albums/e73/mahogoff/IMAG0583.jpg
edcmat-l1
10-29-2011, 05:40 PM
Looks real good. Put a velocity stack on it!
See yas at I vs D.
1fast bird
10-29-2011, 06:17 PM
Car sounds really good! Congrats on the 9's.
TA1364
10-29-2011, 06:22 PM
Whats the motor setup?
Hardtop
10-29-2011, 06:39 PM
Nice runs, your car looked real good. We talked some in the staging lanes.
subhumanzz
10-29-2011, 06:47 PM
Iron 6 litre truck block
Lunati crank and rods
Wiseco pistons, 14.5 to 1 compression
ET ls7 4 inch bore heads
PAC solid roller valve springs
Custom crower 1.8 ratio rockers
crower solid roller lifters
cam motion 261/267 740 lift camshaft
double roller adjustable timing chain
katech ported oil pump
cometic head gaskets
ARP 2000 studs thru the entire motor
fast 4150tb
kooks 1 7/8"
chrs1313
10-29-2011, 09:02 PM
what size is the motor...these were n/a runs correct? nice passes
subhumanzz
10-29-2011, 09:42 PM
It's a 408 n/a , 3350lb.
subhumanzz
10-30-2011, 11:52 AM
thanks, i also see my car in your sig pic from the rental last year.
WheelsUp84z
10-30-2011, 02:33 PM
Car looked and sounded great going down the track! Congrats on getting 9's on the first time out, Suspension is working well for you.
JL ws-6
10-30-2011, 06:55 PM
Are you happy with the motor, and the initial results?
subhumanzz
10-30-2011, 07:14 PM
being the first time out and knowing that it has more in it, yes.
JL ws-6
10-30-2011, 07:50 PM
Good to hear. I have alot of faith that you can get the car to 9.30 by the time you have it 100%.
Car's still heavy... if you can get it to 3000 lbs, or the 2900 I was aiming for with that engine, that alone will have a big impact.
I think the converter needs to be loosened up a touch, get an 8 inch one that will flash up to about 5500 to 5800 and you are really going to see it come to life.
Vaccum pump is going to help, and getting the engine broken in the rest of the way will help too, probably a tenth or so there at least.
If, you spend the $ on a better intake for that motor, I bet there's another 30 hp in it from that. The one that's on there was a good starting point, and I think there's more in the car with it on there, but I'm sure that a better intake more matched to the engine will result in a pretty big gain as well.
Shifting it up around 7800 will help alot too.. that camshaft should make power to 8000
Firehawk441
10-31-2011, 04:32 PM
Congrats on your new best.
edcmat-l1
11-01-2011, 07:04 AM
Velocity stack will be the biggest, cheapest gain.
Cheeks
11-01-2011, 08:19 AM
velocity stack will DEFINITELY help
bad ass runs, congrats on your times
BMR Tech2
11-01-2011, 09:14 AM
Great times!
subhumanzz
11-01-2011, 03:24 PM
Great times!
thanks, the bmr suspension is working well.
1fast bird
11-01-2011, 06:34 PM
Haha, yeah they were the good old days when mine ran. Maybe next year mine will be ready for that rental.
Larry @ AMS
11-03-2011, 09:54 AM
good results and sure with more tweaks and testing you will see the ET drop and MPH climb
I remember going 11.2@122 first few times out and after a season of tests and minor changes went 10.6@126.
blackls1ta00
11-03-2011, 04:06 PM
great et"s,im looking for 9's but im about 5k short.
02sleeperz28
11-03-2011, 04:10 PM
Very nice. Congrats!
silverz28camaro
11-03-2011, 10:36 PM
Car runs/sounds good!!!
JRracing
11-05-2011, 10:01 AM
That is pretty good for the weight. My car runs right at the same et and mph. It is in the 9.90-10.0 range at 133-134 mph but at 2700lb race weight. But my motor is a 13.5:1 383 ci with a th400.
White.Lightning
02-09-2012, 08:31 AM
Nice car. Looks like a fun ride!
JL ws-6
02-09-2012, 11:26 AM
He gets his car to 2700 lbs and it's going to go sub 9.50
ROMERO98Z28
02-12-2012, 10:23 PM
that camaro looks mean! nice ride
