Drag Racing Results - Fastest stock bottom end 6-speed?
View Full Version : Fastest stock bottom end 6-speed?
StangEaterSS
10-29-2011, 06:33 PM
How fast is the fastest stock bottom end 6-speed f-body? I just went 10.20@134 with my heads/cam car on 200 shot, six speeds inc built t-56. might have a bit left in it. tryin to dip into the 9's. anyone with a legit stock motor with only heads/cam power adder ever go 9's?
zacht
10-29-2011, 06:43 PM
subscribing! id like to see some results
whats your combo btw???
StangEaterSS
10-29-2011, 06:55 PM
5.3 truck heads. MS3 cam. 200 shot dry 1 stage. Dan bills tuned. six speeds inc T-56. spec stage 3 clutch. moser 12.
BADD SS
10-29-2011, 07:35 PM
There is one or two h/c 6 speeds...
Are you really spraying a 200 shot, that seems a bit slow no?
StangEaterSS
10-29-2011, 07:46 PM
my bottle pressure was unkown. I sprayed 175 on my bottle (1050psi) 3 passes went 10.30's. jetted it up to 200 shot. .078 jet. then borrowed a full bottle with no gauge and heated it a little bit. no idea on bottle psi. it then went 1 tenth faster to a 10.20. i see the car goin 10.0's. i got a feeling the car on the 6-speed list that went 9.90 or so isnt even a stock motor. its 346ci with forged internals. I bought my car almost new and it really only has heads/cam nitrous.
BADD SS
10-29-2011, 08:12 PM
I wasnt talking about the list, there are quite a few cars not on it or updated... I went 10.95 2years ago, and my times werent updated, then went 10.60 but why bother even posting it, if they dont update? Do you consider rod bolts an issue? If not i know for a fact there are a couple 10.1 cars.
BayAreaSS
10-29-2011, 08:16 PM
Thats a decent time but I think the mph is on the low side for a 200 shot if you are spraying out the hole. I'm sure there has been plenty of stock bottom end cars that have run low 10s
chrs1313
10-29-2011, 08:53 PM
ROBZ* 9.931@138.41; 03 Z06(346); M6; AMR H/C; 3190lbs;12/08
n/a heads cam car, would probably really rip with a shot on it...
StangEaterSS
10-30-2011, 02:23 AM
rod bolts will prolly fall out while driving it to work. lol. the car has had spray on it for 5 years. 90k miles on the car. we trailered it to the track planning on popping the motor. somehow it held together.
StangEaterSS
10-30-2011, 02:26 AM
ya spray 1 stage right out the gate. 1.40 60ft. i think the bottle pressure was low to begin with and then dropped off quickly. trap on 175 shot was 134 and the trap on 200 was also 134 but yet the et was faster. sprayin the last pass with no pressure gauge was just a bad idea. we have no idea what the pressure was to even base anything off of. not sure why it trapped so low. maybe it finally lost all the compression on a few cylinders. lol. put it right on the trailer and never looked at it. who knows.
TA1364
10-30-2011, 10:26 AM
Good passes. You arent to far from 9s.
blue00ZZleeper
10-30-2011, 12:34 PM
Sounds like bottle pressure teetered off after the first run. She deff has lower 10's / high 9's in her if she holds together. RobZ from anger management's record is all motor...not sure what the 6spd/stock bottom end record is...There's a lot of variables. Just the LSX motor? In what body? I'm pretty sure I just read a GMHTP that had a 200 shot stock car running well into the 9's iirc. Has a silver Z28 on the front. Nevertheless, good runs and she has more in her.
StangEaterSS
10-30-2011, 12:45 PM
i'm talking stock bottom end ls1 motored f-body car with a 6-speed. i personally have only seen one go as fast as me. I was just lookin to see if some members here have went 9's. I wouldn't mind pushing now to try and make some sort of a record if i'm that close you know.
BayAreaSS
10-30-2011, 11:43 PM
Get the pressure up and you'll be knocking on the door of 9s :burn:
95civic2005
10-31-2011, 11:25 AM
What's the car run on motor only?
StangEaterSS
10-31-2011, 02:53 PM
I never run the car on motor. I think i've went 11.70 before but it was with only a 1.7 60ft. i'm sure it could go 1.5 60fts on motor if i played with it.
98blueSScamaro
10-31-2011, 03:09 PM
i hope to be running your times next time out N/A with a SBE/346 and 6speed.
StangEaterSS
10-31-2011, 04:34 PM
that would be rediculous. it would have to be one light ass car with some bad ass heads and cam package. my car is a pig almost 3,500lbs and i only made 420hp on motor.
98blueSScamaro
10-31-2011, 05:15 PM
3300 lbs pig here.
studderin
10-31-2011, 05:30 PM
Not sure what 01Z went I think he was a 6speed car then went auto. Auto went 9.9 C/H and 9.6 on spray
LS1 joe went 10.2 camonly
rodney 10.21 camonly
John Deere racer
10-31-2011, 05:36 PM
Ditto....
I was thinking my new set up should run low 10s also
vetteboy2k
11-01-2011, 05:01 PM
To the OP: There are several stock bottom end vettes that have gone high nines with power adders but my favorite is the one mentioned above. lol
StangEaterSS
11-01-2011, 06:21 PM
i'm not concerned with vettes. If my car weighed 3100lbs like a z06 i would be easily in the 9's. I said SBE 6-speed f-bodys.
vetteboy2k
11-02-2011, 12:31 AM
9's are never easy.
Goodluck with it.
buzz12586
11-02-2011, 09:03 AM
What color?
StangEaterSS
11-07-2011, 01:00 PM
out of the guys on the list, i messaged the 9 sec guys. there were 4 i belive that said 346ci. all of them have now responded and all have said they had forged rods and pistons. some were spraying as much as 225 shot. the fastest car on the list faster than my time was 10.04. he had a 100% stock motor with cam and spray. now i'm curious who has went in the 9's but never was added to that list, because there are no cars in the 9's with a stock bottom end on that list.
studderin
11-07-2011, 01:28 PM
what list?
midwestjunk
11-07-2011, 01:32 PM
There is a fastest 6-speed list in the manual transmission forum I belive.
Killer5.3
11-08-2011, 06:20 AM
Had an 01 formula 6 speed with LS6 intake,ported 241 heads, medium xe grind cam (i think 226/230@.050, slp longtubes and high flo cats, 9in w/ 3.89 gears. Car weighed 3550 lbs with my son in it. On a 150 nozzle kit it went 10.64 @132 w/ 1.65 60 ft. Track was not prepped good that day and the only suspension mods were lca and torque arm. Anti -roll and some good adjustable shocks would have help in the 60 ft department I'm sure. and never went back to track before I sold the car. The trap speed was there to run some 10.30's at least with a good 60 ft. Maybe with some weight reduction and 200 shot it would have been in the 9's. So yea it is definitely possible. Good luck with your combo
chrs1313
11-08-2011, 08:32 AM
mid 9s is very attainable with a stock bottom end ls1, m6 on a shot...
98blueSScamaro
11-08-2011, 08:45 AM
what this guy said.
