2001 Trans Am - built Twin Turbo - UPDATED!
Year: 2001
Make: Pontiac
Model: Trans Am
Price: $18000
Mileage: 8000
Private or Dealer Listing: Private Listing
Location (State): PA
Color: Black
Transmission: Manual
Drivetrain: Rear Wheel Drive
I'm going to put up for sale my 2001 twin turbo Trans Am...
I don't have to get rid of it, so I won't take some low-ball number... I have title in hand and I am interested in a quick sale for the right price... Car is located just outside of Pittsburgh, PA
I'm asking 18,000 O.B.O.... I will entertain any offers - but I'm not particularly interested in any trades
The car has 82K miles on it - the turbo kit, built motor, etc. all have 8K miles... The car was built to be a nice weather DD, but nowadays i have 3 cars, so i don't DD it... however, it is still very capable of that...
Car was just retuned - please see later post for more detail... made 615/607 on a Mustang dyno that is known to read 22% low ... so that's 788/778 on a dynojet... this is on 13.5psi, 15* of timing and 11.2 A/F ratio
I know one big concern people have with a massive hp car like this is its ability to take a long trip... this car has been on numerous long trips (several hours) non-stop, and has even made 1 trip across the state (6 hours) without a single hiccup.. i havent' checked it in a long time, but it has gotten upwards of 30mpg on long trips, thanks to the 3.08 gears
The black exterior is flawless - seriously looks like a car with 10K miles...
Interior is perfect as well.. Car still has full heat and A/C...
Modifications
Engine:
• Stock aluminum block LS1 (5.7L), bored .010 over (348 ci)
• Polished crank and fully balanced rotating assembly
• -16cc Mahle forged pistons w/ file-to-fit rings (filed for blown/turbo application)
• Eagle 4340 forged H-beam connecting rods w/ ARP L19 bolts
• Clevite bearings throughout
• Ported and polished 5.3 heads (heads/valves have 3000 miles)
• ARP head studs
• GM MLS head gaskets
• Comp Cams 220/224 .564/.568 115 lsa, custom turbo grind cam – custom grind for mid-range torque
• LS2 timing chain
• LS6 ported oil pump
• LS6 intake manifold
• Patriot Performance Gold dual springs, with titanium locks and retainers
• LS7 lifters
• NGK BR7EF plugs
• Full A/C, heater, etc.
Turbo Kit:
• 58mm Precision turbos (2) – T4
• Custom built, thick walled stainless steel headers
• 3” Stainless steel downpipes, connecting into 4” stainless exhaust, then dumped before the axel
• Stainless steel charge piping
• Very large 2in – 1out air-to-air intercooler (polished)
• 38mm Tial wastegates (2)
• 50mm Tial Blow-off valve
• eboost2 Electronic boost controller
Fuel System:
• Twin 255lb Walbro fuel pumps (2)
• Custom pressed steel-braided fuel lines
• Aeromotive fuel pressure regulator
• Aeromotive fuel rails
• 83# high-impedance fuel injectors
• Mallory fuel gauge isolator
• Snow Performance Boost Cooler methanol injection kit
Supporting Mods:
• T56 6-speed manual transmission
• Spec Stage 3+ clutch – 1000 ft.lbs tq. capacity
• Custom aluminum driveshaft
• Moser 12-bolt rear end
• Detroit True-trac differential w/ 3.08 gear ratio
• 18" Boyd Coddington Smoothie II wheels ... new BFG TA KDW tires on front and new Hoosier Drag Radials on the rear
• A-pillar 3 gauge pod – wideband o2 (a/f), fuel (psi), boost/vacuum (psi/hg) and eboost2 in the left vent
• Custom short-throw shifter
• Custom “in-floor” subframe connectors (2”x4”)
• BMR tubular K-member
• Polyurethane motor mounts
• US Exotics Superhawk fiberglass hood (1 of 500 made)
• Custom 3-bar speed density tune
-Brand new Spec 3+ clutch just installed... 500 miles on the clutch
Please PM and i can share my phone number to serious buyers...
ttt...
the new clutch was installed this past weekend and i picked the car up today.... feels absolutely amazing... put the same Spec 3+ clutch in the car, but this time it feels WAY better...
i'll put a couple hundred miles on her, and then get a re-tune...
If there's any interest in the meantime, please PM me...
Unfortunately we didn't get on the dyno yesterday... Just ran out of time and I was last on the list - he didn't have the time to completely retune the car, and it appear like that is what will be necessary, as i think the current tune is locked and can't be just tweeked...
As long as the weather cooperates, i'm sure it'll get finished up here pretty soon... thsi weeks weather doesn't look good, but we'll just have to hold out and wait for some good weather
bump... the weather and my work schedule haven't been able to work together, but i'm hoping the updated tune will get done real soon....
please PM with interest... price is negotiable...
