Not making power on nitrous
Old 10-30-2011, 07:27 PM
Dirty Vegas's Avatar
Default Not making power on nitrous
Spraying 150ish? dry. Hits like a mad man on the initial hit then falls flat. On this pass, I spun out of the hole, got planted and hit it. Let off for 1-2 switch, hit it again in 2 but it didn't pull hard. Let out middle of 2, hit it again in 3 and had nearly nothing there. Ended up going 11.6@119 with a 1.81 60'. Previous pass on motor went 11.80@112 with a 1.55 60'. Pass starts 2 mins into the log. 12.0ish AFR most of the way down and going fat up top. Any ideas?
File Type: hpl
Old 11-01-2011, 07:58 AM
n20z28's Avatar
Have u check ur filters in the fittings or might check line itself and nozzle and jets for dirt... sounds like has something goin on like that
Old 11-02-2011, 12:49 AM
Don't have any filters in the fittings, nor a stand alone filter either. I'll take it all apart and look for any debris.
Old 11-02-2011, 04:44 PM
bad6as's Avatar
looking at the log its holding a steady 15.5* timing. iat drop very low thoe
m6 i assume?
hows the clutch?
Old 11-02-2011, 05:44 PM
BLK02WS6's Avatar
Sounds like all fuel and no N2O... test it and see if it sprays...
Old 11-02-2011, 07:41 PM
n20z28's Avatar
He said its dry kit
Old 11-03-2011, 06:15 PM
BLK02WS6's Avatar
Originally Posted by n20z28
He said its dry kit
Still could be a fuel only issue - not all dry setups spray the MAF to add the fuel... in fact, the better ones don't...
Old 11-03-2011, 06:17 PM
bad6as's Avatar
idc dosent look like it jumps up much in the logs
Old 11-03-2011, 06:22 PM
BLK02WS6's Avatar
Don't have HPtuners on this laptop, so I couldn't see the log... but 15.5* and no nitrous will be a dog as well... for whatever reason, doesn't sound like its spraying...
OP - Do you have a fuel pressure safety switch?
Old 11-03-2011, 06:25 PM
bad6as's Avatar
is this kit on a wot switch, a push button?
whats the fuel system made of?
pics and specs of teh kit?
Old 11-04-2011, 12:58 AM
A4, on a pushbutton, single NX lightning solenoid and a typical dry nozzle.
