converter stall?
Old 10-31-2011, 05:40 AM
Restricted User
zx2ner25's Avatar
Default converter stall?
I have a pretty bad rear main seal leak, but since i hate doing all the labor to remove the trans just to fix one small problem, I was going to change my converter as well...
The car is a 2002 trans am w/90000 miles, Its my dd. has lid, bellows, and ram air hood.
the most this car will see until i get another car to rebuild is a full exhaust hopefully by summer next year.
So my question is, what size stall should i go with for a daily driven car with mild to no bolt ons, also, is there anything else i should do while the trans is out, or is there anything else i need to install, or do to make the converter work right?
Old 10-31-2011, 06:00 AM
blk/slvr02ss's Avatar
Anywhere between a 3000-3600 will b fine for a Daily Driver !
Old 10-31-2011, 06:02 AM
Restricted User
zx2ner25's Avatar
thank you, I was thinking about a yank 3600 ss series
Old 10-31-2011, 06:38 AM
lemons12's Avatar
3200-3600. I suggest PTC.. Get a good transmission cooler, it is a must.
Old 10-31-2011, 07:16 AM
Yes that is what i had in my 2002 Camaro SS and a B&M Tranny Cooler !
Old 10-31-2011, 07:32 AM
Circle-D's Avatar
Like mentioned above, something in the 3000+ range is suggested, with the 3600 for even better performance. Adding a cooler is a really good idea, keeping the trans temps down is huge for trans life. Would be glad to help you go over the options to see what will be best for your setup. Let me know if you need any help.
Chris
Old 10-31-2011, 07:40 AM
00'WS6Rocket's Avatar
Mines a dd and i have a vig3200. Im glad i didnt go bigger its perfect for me. 2000 ta true duals longtube headers ls6 manifold.
Old 10-31-2011, 07:51 AM
Restricted User
zx2ner25's Avatar
di you have to do anything else aside from installing it, such as a shift kit, or tuning?
Old 10-31-2011, 08:35 AM
Nope only thing was transmission cooler. I've been driving it untuned and it runs perfect, no check engine. Shifts fine and no noticable gas/mileage loss, either. If i were you if you go any more then 3200 id would try to find someone in your area with that size stall and drive with them or test drive if theyre willing, just so you know what it feels like. I know alot of people will say go bigger but im glad i got the 3200.
Old 10-31-2011, 08:52 AM
lemons12's Avatar
A vig 3200 is more like a 3400-3500 most likely. My 4000 was more like a 4400.
Old 10-31-2011, 08:55 AM
senicalj4579's Avatar
Do this!
Old 10-31-2011, 09:20 AM
Really? I wasnt aware of that.
Old 10-31-2011, 09:37 AM
lemons12's Avatar
Yes sir, Vigs are known for flashing a few hundred RPMs higher than what they are rated at.
Old 10-31-2011, 12:20 PM
LS1Tech Sponsor
FTICONVERTERS's Avatar
There are several options that are available for your application from billet 9.5" to 11" stamp steel cover economical converters. We can spec one out for you or you can go to our website and fill out a spec sheet. if time is of the essence JEGS.com has our most popular part numbers in stock.
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old 10-31-2011, 01:25 PM
SuperSlow02's Avatar
+1 for FTI. Do as Greg says. The man knows his converters
