Setting up Adj. Panhard Rod
Old 03-10-2004, 08:52 PM
APeteSS's Avatar
Question Setting up Adj. Panhard Rod
What is the 'official' way to set up an adjustable panhard rod? I matched mine to the length of my stock piece. When my car was lowered, I shortened the rod accordingly. I'm going low again and getting 10.5" wides in the rear so I need to have the rear end set up properly. Let me know.
As usual, Thanks
Old 03-10-2004, 11:11 PM
Bad Blu Formula's Avatar
Jack up the car for the rear. Set jack stands under the frame so the rear end hangs. Then get under there and adjust. Last get out from under the car and measure that both sides are equal then you're done.
Old 03-10-2004, 11:20 PM
DARK AGE 53's Avatar
This might help. http://www.bmrfabrication.com/instructions/phr002.htm
Al
Quick Reply: Setting up Adj. Panhard Rod
