General Maintenance & Repairs - Bad MAF?
mjs1012
11-02-2011, 12:45 PM
Not sure if this in the right section but Iv been getting bank 1 and 2 lean codes that have been going on randomly. I checked for vacuum leaks and found nothing. Today I cleaned the MAF with cleaner then the ses light turned off. The next time I went to start the car, it came back on when I was in my driveway so while it was running I unplugged it and it still ran as if i did nothing. Then I ended up taking it off completely and it still ran the same. Not sure if this is relevant or not but the car has a high number of miles and when I bought it the MAF was on backwards (Screen facing throttle body) with all sorts of crap in it. Is my Maf bad or should there be something else I should look for
Nowhereman
11-02-2011, 01:04 PM
Did you replace the MAF in it's normal position?
The MAF could be bad if someone messed with it.
Clean it, install back into engine and check it again.
Un plug your battery for a few minutes 1st.
Then see what happens.
If it corrects itself, your ok.
If not, time for a new MAF.
mjs1012
11-02-2011, 01:07 PM
thanks, ya I put it in its normal position (screen facing lid)
jimmyblue
11-02-2011, 02:21 PM
Lean codes are more likely O2 sensors than MAF, although
an extra grimy one could bend you lean.
mjs1012
11-02-2011, 02:32 PM
I actually changed the front o2s about a month ago which is when I got the same codes last so idk if that'd do it
wssix99
11-03-2011, 08:34 AM
How does the car run? If the MAF was bad, it would run rough. If it runs fine, many different sensors can cause the car to run lean. (This is going to be a tough one.)
mjs1012
11-03-2011, 01:12 PM
The car ran real rough. i actually went out and got a reman MAF from autozone and the code went away.
chrysler kid
11-03-2011, 01:55 PM
I ran my mad backwards for a while without any ill effects, seems to just read air going past it regardless of position. Bad mad symptoms could be hard starts and running rough
ccrook19
11-03-2011, 10:19 PM
Most likely a bad Maf.. highly doubt its the 02 sensors.. have you replaced your fuel filter??
FiredUpZ28
11-03-2011, 10:46 PM
Exhaust leaks before the front 02 can cause a false lean. Hear any ticking coming from the headers/manifolds?
Nowhereman
11-04-2011, 12:09 AM
Run a bottle of Lucas fuel injector cleaner through it.
One small bottle will clean out your system real nice.
If that doesn't help, it's gotta be a bad MAF.
LS6427
11-04-2011, 12:38 AM
I had Bank 1 and Bank 2 lean codes 2 months after putting in 2 new 02 sensors. One was a dud.......and it caused the other Bank to throw codes too.
Get a scan and see how the 02 sensors are switching.......one of mine showed 0-4, it was a dud. It caused the other to show lean, slow repsonse and low voltage CODES.
I put 2 new ones in tonight.....all better.
Moral of the story: One bad 02 sensor will cause the other one to throw false codes. Real codes, but false because the bad 02 sensor is messing up everything....
lt1pwr1
11-04-2011, 08:19 AM
As common as they go bad on these cars, I'm surprised nobody has mentioned your intake gaskets possibly leaking. On a cold start you can spray some carb cleaner around the intake and see if your idle changes.
With these codes, it can be alot of things but the key is to figure it out as cheaply as possible. I would hold off on buying new o2's or a new MAF until you exhaust the free or cheaper options first.
LS6427
11-04-2011, 09:57 AM
True. Thats one of the things I tried before buying anything. It wasn't the gaskets on mine...BUT 5-6 years ago I replaced both head gaskets and ALL of the intake bolts had come a little loose, not bad, but they all turned a couple times to get them tight again.
mjs1012
11-06-2011, 07:43 PM
Thanks guys I already got a new Maf and o2's, and yes, I recently changed the fuel filter. After the code went away I was able to borrow a scan tool and it popped up with a low voltage code, I forgot to write it down so idk the number.
LS6427
11-06-2011, 10:06 PM
You probably just have a bad "NEW" 02 sensor.....like I just went through. One bad one will make the other Bank throw codes......as I said above. If one 02 sensor is showing anything wrong by way of a scan while the engine is running...change it.
mjs1012
11-07-2011, 10:51 AM
ill check the o2s once I have the time. the ses light is off and I think i hear an exhaust leak so maybe thats what could be the cause.
FiredUpZ28
11-07-2011, 01:10 PM
I'd still scan it. There could be codes even if the MIL isn't on.
mjs1012
11-07-2011, 01:19 PM
I did on Friday and the only other one that showed up was a low voltage code and I forgot to write it down
LS6427
11-07-2011, 04:51 PM
If you have an exhaust leak within like 10 inches AFTER the 02 sensor.......it will cause problems. The air in the exhaust tubes actually go back and forth in them......if it sucks air in and reaches the 02 sensor thats bad.
wssix99
11-07-2011, 05:22 PM
It sounds like you had a fatal MAF code, which you fixed by getting a new sensor: http://www.obd-codes.com/p0102
After you put in the new sensor, did you do a learn procedure on the PCM? After you put in a sensor to fix these kinds of things you need to:
- Erase the stored codes
- Take the car for a short drive on the highway for the PCM to "learn" the new sensor settings.
- Check to see if you have any new codes
If your MAF was reporting low air, the car would cut back on fuel, causing your lean condition. You'll need to get out and drive so the car can re-learn your air/fuel mixtures.
mjs1012
11-09-2011, 02:07 PM
I drove it and within 5 miles it must have Reset the PCM. The description in the link was what I was feeling....sluggishness And down on power
wssix99
11-09-2011, 02:47 PM
Did you erase the codes and then re-scan?
mjs1012
11-09-2011, 03:03 PM
I erased the codes but never scanned I'll see if I can get a scan tool again
FiredUpZ28
11-09-2011, 07:03 PM
Yea always scan again after a test drive a majority of codes need more than one warm-up cycle to set.
mjs1012
11-09-2011, 07:11 PM
Thanks a lot guys
